St4000dm000 After Head change Message Disc FW failed to load
Arihant
Postby Arihant » 17.11.15, 14:44
Seagate 4TB hdd has clicking noise. It has head crashed. I have replace the head.
Now No cliking noise. Motor is runing smoothly. Terminal shows this message.
"Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Disc FW failed to load"
How to resolve?
Thanks,
Amit Shah
Arihant Data Recovery, India
Sergey_TS
Re: St4000dm000 After Head change Message Disc FW failed to load
Postby Sergey_TS » 17.11.15, 16:58
You need to get terminal access and check heads reading and writing via terminal. Then check important sysfiles. Maybe you will need to upload loader
Arihant
Postby Arihant » 25.11.15, 10:51
REplaced the pcb and solved.
Thanks,
Thanks,
Amit Shah
osity
Postby osity » 13.07.16, 22:15
Did you need to swap 1 ROM chip or 2?
Postby Amarbir[CDR-Labs] » 14.07.16, 12:24
osity wrote:Source of the post Did you need to swap 1 ROM chip or 2?
What,
I Think They Have Only 1 Rom
osity
Postby osity » 14.07.16, 12:42
I thought so too.
my drive stopped spinning after it was imaging fine for a while. I remove the TVS and it was fine for a few minutes and then stopped spinning again.
I changed the PCB/rom and the drive now spins again but I get this FW Error and the drive now detects as 3.68GB.
