840 Evo support
840 Evo support
Just a few words about next release of PC-3000 SSD. In new version of software, we will add 840EVO drives finally
Also, as I remember, there should be PM851 also! It is based on the same type of CPU.
Re: 840 Evo support
Hi All,
i can identify the Samsung 850 evo with full geometry. but i couldn't read any sectors! is there a solution for that please?
Thank You for your help!
Re: 840 Evo support
Before this drive will not be added to PC-3000 SSD Utility, access to user data in case of SA logical problem will be not available...
Re: 840 Evo support
Hi Roman,
I try to use DE for imaging but i have no access to the partitions ( table empty ), and no access to the datas.
Thank You
Thank You
Re: 840 Evo support
Did you try to launch RAW recovery? Did you find any file headers?
Maybe this drive was in PC which use bitlocker?
Re: 840 Evo support
I have quite the same problem with a 850 EVO it is detected correctly (Model,SN and Capacity) but as soon as we try to access it ... it comes Busy and of course no access to any sector.
Any other ideas ?
Many thanks
Alain
Belgium
Any other ideas ?
Many thanks
Alain
Belgium
Re: 840 Evo support
Hello Alain!
Actualy Samsung 850 EVO are not supported right now. We are waiting them in next PC-3000 SSD release. Hope it will appear somewhere in the end of January-February 2016.
Re: 840 Evo support
Any idea when this update will be released? Have a Samsung 850 Pro that needs recovery and been waiting for this update for a few months now. Thanks! Brian
Re: 840 Evo support
Hi Brian!
Hardly to say, but I hope the it would be in the end of April. PC-3000 SSD is a part of PC-3000 UDMA-E\Express\Portable, and our developers want to add a lot of new features in main HDD Utilities, that's why we need more time
Re: 840 Evo support
Thanks for the update Roman!
Re: 840 Evo support
Roman,
Do you still have so far no solution for 850 Evo seires? When Do you think that the utility will be released for htat model ?
Thank You !
Thank You !
Re: 840 Evo support
850 EVO has more complex system of loader uploading. A lot of encrption. Developers are still trying to find the way, but right now - it's not ready yet.
Re: 840 Evo support
Hi Roman,
Thank You!!
Thank You!!
Re: 840 Evo support
Has anything changed with support for the 850 Evo? We have one that ID's correctly but can not read any sector.
Re: 840 Evo support
850 EVO has new type of terminal data transfer with encryption. Right now we don't find the way how to beat it. Need more time.
