How to recover data from a monolith (microSD card)
Re: How to recover data from a monolith (microSD card)
No, we do not need to add additional solder tin into the end of wire. We just need to "wash" wire in rosin, when you will start to solder it to BGA balls on monolith, rosin will remove all oxids from cupper and will allow us to make better and more tough solder.
Roman_TS wrote:Source of the post No, we do not need to add additional solder tin into the end of wire. We just need to "wash" wire in rosin, when you will start to solder it to BGA balls on monolith, rosin will remove all oxids from cupper and will allow us to make better and more tough solder.
Thank you Roman for The Information,I Get Your Point
italyassistance wrote:One thing is not mentioned in the video: how many degrees should the soldering iron temperature be set to avoid it melting the BGAs that are too close?
USB Solder iron needle is very thin. It will not melt nearby pins even if you heat it up to +300C
