The PC power supply took some sort of hit. The drive starts up with normal sounds, comes ready, but no ID. F3 utility needs to be started with alternate initialization method. At this point using tools/utility extensions/service information objects all system files appear to be readable but, although they're all listed, no service modules can be read. Heads test passes; translator appears to be loaded. Looks to be a firmware issue but I can't be sure yet. Any direction on this would be appreciated. Terminal startup:
Boot 0x10M
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMTFileHandler: EXCEPTION: Failed MCMT read request
At this pooi
Seagate ST500DM0002 problem
Re: Seagate ST500DM0002 problem
Problem solved after I noticed that system file 346 was damaged. Copied it from another drive with close firmware version and all is now well.
Thanks to AJ2008 for his input.
- cuumaytinh
great !
I've never noticed system file "346" --> Would you mind sharing how you determined it was damaged?
I got data after rewrite Sysfile 346
300ddr wrote:Source of the post I've never noticed system file "346" --> Would you mind sharing how you determined it was damaged?
you can check it by command 'r346' onT level in terminal
Good Very Good
When I followed your adviced, I recovered data.
Thank you.
Thank you.
