I have ST3500413AS Only 235188916 sector reading i will try recover translator but problem is same any one any solution please help ....
HDD family detecting...
Family ID: 3F
Selected family......................... : 3F, Pharaoh
Model by ID............................. : ST3500413AS
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ PH0U2D.CCD6.KA029Y.JC66
Detecting Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 2
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
ID Len
0 4 Reserved Defect Table (SA defect table)
3 3787 Primary Defect File (P-List))
4 12 Servo Adaptive Parameter File (SAP)
8 4800
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 1172 R/W Operating Parameters (translator, etc)
33 4576
35 26 SMART Data
3A 4
Collecting DT Infos...
ID MemOffs Len
0 6037200 33792 Read Adaptive Parameters File (RAP)
1 6037000 512 Controller Adaptive Parameters File (CAP)
4 4002C00 4096 Servo Adaptive Parameter File (SAP)
602BE00 4096
total 8192
A 60B5DE0 3072 Seek Profile
13 60C27C8 864 Dependent Zone Table for User Area
14 60C2B28 96 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60C05CC 8700 Dependent Zone Group Tables for User Area
1C 60C048C 320 Dependent Zone Group Tables for System Area
1D 6037220 352 VBAR Configuration File
1E 60374B0 2416 Zone Format Parameters File
ID MemOffs Len
2 6037380 304 Zone Table
602BE00 4096
total 8192
6 281044 40996 Servo Flaw Table
16 6037200 32 Drive Configuration Table
17 6039240 1216 Temperature Control Configuration
1F 618D67C 1088 RW working user preamp table
20 618DABC 64 RW working system preamp table
Collecting DT Infos completed
Searching CFW OVL FID in RAM............ Ok
Executing user command.................. : Translator regeneration with defects information transfer from Alt-list
ASCII Diag mode
F3 T>/
F3 T>m0,6,3,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
Test : Clearing Non Resident G-List
Reading defect list...
Test : Edit HDD ID (RAM)
Writing Saved Mode Pages...
Test : Edit HDD ID (ROM)
Parsing container segment....... Flash ROM image
Segment: BOOTFLOADER
Parsing segment....... BOOTFLOADER
End parsing segment... BOOTFLOADER
Segment: SHAREDFW
Parsing segment....... SHAREDFW
End parsing segment... SHAREDFW
Segment: NONREDN_CNT_0
Parsing container segment....... NONREDN_CNT_0
Segment: ADP_SERVO_DIR
Parsing segment....... ADP_SERVO_DIR
End parsing segment... ADP_SERVO_DIR
Segment: CAP
Parsing segment....... CAP
End parsing segment... CAP
Segment: RAP
Parsing segment....... RAP
End parsing segment... RAP
Segment: SAP
Parsing segment....... SAP
End parsing segment... SAP
Segment: SFW
Parsing segment....... SFW
End parsing segment... SFW
Segment: SHELL
Parsing segment....... SHELL
End parsing segment... SHELL
End parsing container segment... NONREDN_CNT_0
Segment: BOOTFW_CONT_0
Parsing container segment....... BOOTFW_CONT_0
Segment: BOOTFW_DIR
Parsing segment....... BOOTFW_DIR
End parsing segment... BOOTFW_DIR
Segment: GENERAL_DATA
Parsing segment....... GENERAL_DATA
End parsing segment... GENERAL_DATA
Segment: IAP
Parsing segment....... IAP
End parsing segment... IAP
Segment: BOOTFW
Warning! Segment used space check sum is not zero: 00009ED1
End parsing container segment... BOOTFW_CONT_0
Segment: BOOTFW_CONT_1
Parsing container segment....... BOOTFW_CONT_1
Segment: BOOTFW_DIR
Segment: IAP
Segment: BOOTFW
End parsing container segment... BOOTFW_CONT_1
End parsing container segment... Flash ROM image
Test : Edit HDD ID (terminal)
Test : Translator regeneration
Test : Recover translator
First start
Translation "forks" list file........... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Pharaoh\ST3500413AS-JC66-S2A3922J\Defects\TranslationForks.lba
Maximal defect chain length............. : 64
Take into account P-List................ : Yes
At ambiguity hide "left" UNC............ : Yes
Process "32 byte tail" bug.............. : Yes
Execute Reset after defect hiding....... : Yes
HDD resources backup
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Pharaoh\ST3500413AS-JC66-S2A3922J\Data\SABackup\
Switching Autoreassign OFF...
G-List erase...
Translator regeneration...
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Start scanning...
"Fork" searching: 0 - 976773167
Verify sectors ext error Device error detected "UNC"
"Right fork", LBA = 00235188892, pattern 0x00
Defects hiding (P23)...
Moving defects to Slip-List...
"Fork" searching: 235188892 - 976773167
Error processing "fork": Terminated by user
Test : Non Resident G-List editing
Terminated by user : Error starting command "En Tech" (Drive is not ready)
Defect list export...
Non Resident G-List writing...
Start from LBA.......................... : 235100000
HDD ID reading...
G-List erase...
Start scanning...
"Fork" searching: 235100000 - 976773167
PRd: Err Rd Ph Sect BF7D:1:4(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:4(1)! Tech state 0x72, 0x03110081
LBA : 235188892
"Fork" searching: 235188893 - 976773167
"Right fork", LBA = 00235188893, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:A(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:A(1)! Tech state 0x72, 0x03110081
LBA : 235188893
"Fork" searching: 235188894 - 976773167
"Right fork", LBA = 00235188894, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:19(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:19(1)! Tech state 0x72, 0x03110081
LBA : 235188894
"Fork" searching: 235188895 - 976773167
PRd: Err Rd Ph Sect BF7D:1:1A(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:1A(1)! Tech state 0x72, 0x03110081
LBA : 235188895
"Fork" searching: 235188896 - 976773167
PRd: Err Rd Ph Sect BF7D:1:1B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:1B(1)! Tech state 0x72, 0x03110081
LBA : 235188896
"Fork" searching: 235188897 - 976773167
"Right fork", LBA = 00235188897, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:1E(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:1E(1)! Tech state 0x72, 0x03110081
LBA : 235188897
"Fork" searching: 235188898 - 976773167
"Right fork", LBA = 00235188898, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:20(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:20(1)! Tech state 0x72, 0x03110081
LBA : 235188898
"Fork" searching: 235188899 - 976773167
"Right fork", LBA = 00235188899, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:26(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:26(1)! Tech state 0x72, 0x03110081
LBA : 235188899
"Fork" searching: 235188900 - 976773167
"Right fork", LBA = 00235188900, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:28(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:28(1)! Tech state 0x72, 0x03110081
LBA : 235188900
"Fork" searching: 235188901 - 976773167
"Right fork", LBA = 00235188901, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:2B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:2B(1)! Tech state 0x72, 0x03110081
LBA : 235188901
"Fork" searching: 235188902 - 976773167
"Right fork", LBA = 00235188902, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:2E(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:2E(1)! Tech state 0x72, 0x03110081
LBA : 235188902
"Fork" searching: 235188903 - 976773167
"Right fork", LBA = 00235188903, pattern 0x00
PRd: Err Rd Ph Sect BF7D:1:31(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:31(1)! Tech state 0x72, 0x03110081
LBA : 235188903
"Fork" searching: 235188904 - 976773167
PRd: Err Rd Ph Sect BF7D:1:32(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:32(1)! Tech state 0x72, 0x03110081
LBA : 235188904
"Fork" searching: 235188905 - 976773167
PRd: Err Rd Ph Sect BF7D:1:33(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:33(1)! Tech state 0x72, 0x03110081
LBA : 235188905
"Fork" searching: 235188906 - 976773167
PRd: Err Rd Ph Sect BF7D:1:34(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:34(1)! Tech state 0x72, 0x03110081
LBA : 235188906
"Fork" searching: 235188907 - 976773167
PRd: Err Rd Ph Sect BF7D:1:35(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:35(1)! Tech state 0x72, 0x03110081
LBA : 235188907
"Fork" searching: 235188908 - 976773167
PRd: Err Rd Ph Sect BF7D:1:36(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:36(1)! Tech state 0x72, 0x03110081
LBA : 235188908
"Fork" searching: 235188909 - 976773167
PRd: Err Rd Ph Sect BF7D:1:37(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:37(1)! Tech state 0x72, 0x03110081
LBA : 235188909
"Fork" searching: 235188910 - 976773167
PRd: Err Rd Ph Sect BF7D:1:38(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:38(1)! Tech state 0x72, 0x03110081
LBA : 235188910
"Fork" searching: 235188911 - 976773167
PRd: Err Rd Ph Sect BF7D:1:39(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:39(1)! Tech state 0x72, 0x03110081
LBA : 235188911
"Fork" searching: 235188912 - 976773167
PRd: Err Rd Ph Sect BF7D:1:3A(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:3A(1)! Tech state 0x72, 0x03110081
LBA : 235188912
"Fork" searching: 235188913 - 976773167
PRd: Err Rd Ph Sect BF7D:1:3B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:3B(1)! Tech state 0x72, 0x03110081
LBA : 235188913
"Fork" searching: 235188914 - 976773167
PRd: Err Rd Ph Sect BF7D:1:3C(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:3C(1)! Tech state 0x72, 0x03110081
LBA : 235188914
"Fork" searching: 235188915 - 976773167
PRd: Err Rd Ph Sect BF7D:1:3D(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect BF7D:1:3D(1)! Tech state 0x72, 0x03110081
LBA : 235188915
"Fork" searching: 235188916 - 976773167
"Right fork", LBA = 00235188916, pattern 0x00
Maximal defect chain length is reached!
Try to analyse the HDD manually or increase the maximal defect chain length!
LBA : 235188916
Bikram
Sector Reading Problem
