Hitachi HTS543225L9A300 not showing ID!!
VaibhavS
Postby VaibhavS » 05.08.15, 11:36
Hello everyone, I've got a HDD whose details are as follows,
Hitachi 2.5"
Model - HTS543225L9A300
Capacity - 250GB
Spinning normal. getting redy.
When clicked Auto Detect, shows ABR and ERR.
There are three utilities - Hitachi IBM, Hitachi IBM-ARM, Native 2.5 inch families.
Asking for COM port in 2.5 inch utility but no terminal port available in HDD.
And shows the following log when tried Custom Family in Hitachi-IBM utility -
Techno mode key......................... : Error
WARNING! SET FEATURES subcommand required to spin-up after power-up!
Loading data for correction of HDD family handling settings from section HTS5416J9
Loading data for correction of HDD family handling settings from section HTS5425K9
Selected family......................... : CUSTOM
Model by ID............................. :
Loading data for correction of HDD family handling settings from section HTS5432L9
NV-RAM reading.......................... : Ok
Loading modules table................................................. : Ok
Error : .............................................................. : Error executing loading "open" modules dir command
Loading zone allocation table......................................... : Ok
How to handle this HDD?
pcimage
Re: Hitachi HTS543225L9A300 not showing ID!!
Postby pcimage » 06.08.15, 08:23
Family autodetect does not work for Hitachi 2.5".
Select family manually from model number and check modules. There will probably be some damaged ones there.
VaibhavS
Postby VaibhavS » 06.08.15, 09:03
Thanks for reply,
I manually selected family..
in IBM -> costume mode -->HTS5416J9..
Loading data for correction of HDD family handling settings from section MEM_P
It shows..
its Ready.. No Model, Serial,
Capacity 0MB
Firmware C40C
Its correct Output ? What next to do ?
Postby AJ2008 » 06.08.15, 10:53
pcimage already explained next steps you need to take:
pcimage wrote:Select family manually from model number and check modules. There will probably be some damaged ones there.
VaibhavS
Postby VaibhavS » 06.08.15, 13:31
Hello all,
Kindly find below the result of modules. What is the interpretation? And how to solve these errors in the modules?
Test : SA structure test
Module checking
Module RSVD Copy 0...................... : Ok
Module RSVD Copy 1...................... : Ok
Module RSVD Copy F...................... : Error
Module RESF Copy 0...................... : Ok
Module RESF Copy 1...................... : Ok
Module RESF Copy F...................... : Ok
Module RAM0 Copy 0...................... : Ok
Module RAM0 Copy 1...................... : Ok
Module RAM0 Copy F...................... : Ok
Module OVR0 Copy 0...................... : Ok
Module OVR0 Copy 1...................... : Ok
Module OVR0 Copy F...................... : Ok
Module RESF(1) Copy 0................... : Ok
Module RESF(1) Copy 1................... : Ok
Module RESF(1) Copy F................... : Ok
Module PTCH Copy 0...................... : Ok
Module PTCH Copy 1...................... : Ok
Module PTCH Copy F...................... : Ok
Module CNS1 Copy 0...................... : Ok
Module CNS1 Copy 1...................... : Ok
Module CNS1 Copy F...................... : Ok
Module RWCN Copy 0...................... : Ok
Module RWCN Copy 1...................... : Ok
Module RWCN Copy F...................... : Ok
Module ZONE Copy 0...................... : Ok
Module ZONE Copy 1...................... : Ok
Module ZONE Copy F...................... : Ok
Module PTRT Copy 0...................... : Ok
Module PTRT Copy 1...................... : Ok
Module PTRT Copy F...................... : Ok
Module SRVP Copy 0...................... : Ok
Module SRVP Copy 1...................... : Ok
Module SRVP Copy F...................... : Ok
Module SRVM Copy 0...................... : Ok
Module SRVM Copy 1...................... : Ok
Module SRVM Copy F...................... : Ok
Module CHNL Copy 0...................... : Ok
Module CHNL Copy 1...................... : Ok
Module CHNL Copy F...................... : Ok
Module IDNT Copy 0...................... : Ok
Module IDNT Copy 1...................... : Ok
Module IDNT Copy F...................... : Ok
Module SN00 Copy 0...................... : Ok
Module SN00 Copy 1...................... : Ok
Module SN00 Copy F...................... : Ok
Module MISC Copy 0...................... : Ok
Module MISC Copy 1...................... : Ok
Module MISC Copy F...................... : Ok
Module ICES Copy 0...................... : Ok
Module ICES Copy 1...................... : Ok
Module ICES Copy F...................... : Ok
Module MLBA Copy 0...................... : Ok
Module MLBA Copy 1...................... : Ok
Module MLBA Copy F...................... : Ok
Module QMCN Copy 0...................... : Ok
Module QMCN Copy 1...................... : Ok
Module QMCN Copy F...................... : Ok
Module SMRT Copy 0...................... : Ok
Module SMRT Copy 1...................... : Ok
Module SMRT Copy F...................... : Ok
Module PNID Copy 0...................... : Ok
Module PNID Copy 1...................... : Ok
Module PNID Copy F...................... : Ok
Module ABLP Copy 0...................... : Ok
Module ABLP Copy 1...................... : Ok
Module ABLP Copy F...................... : Ok
Module ABLD Copy 0...................... : Ok
Module ABLD Copy 1...................... : Ok
Module ABLD Copy F...................... : Ok
Module SSTL Copy 0...................... : Ok
Module SSTL Copy 1...................... : Ok
Module SSTL Copy F...................... : Ok
Module SERL Copy 0...................... : Ok
Module SERL Copy 1...................... : Ok
Module SERL Copy F...................... : Ok
Module SSST Copy 0...................... : Ok
Module SSST Copy 1...................... : Ok
Module SSST Copy F...................... : Ok
Module SKPO Copy 0...................... : Ok
Module SKPO Copy 1...................... : Ok
Module SKPO Copy F...................... : Ok
Module DCOT Copy 0...................... : Ok
Module DCOT Copy 1...................... : Ok
Module DCOT Copy F...................... : Ok
Module SRIF Copy 0...................... : Ok
Module SRIF Copy 1...................... : Ok
Module SRIF Copy F...................... : Ok
Module BULK Copy 0...................... : Ok
Module BULK Copy 1...................... : Ok
Module BULK Copy F...................... : Ok
Module ALTT Copy 0...................... : Ok
Module ALTT Copy 1...................... : Ok
Module ALTT Copy F...................... : Ok
Module DBGC Copy 0...................... : Error
Module DBGC Copy 1...................... : Error
Module DBGC Copy F...................... : Ok
Module OFDT Copy 0...................... : Ok
Module OFDT Copy 1...................... : Ok
Module OFDT Copy F...................... : Ok
Module SMRA Copy 0...................... : Ok
Module SMRA Copy 1...................... : Ok
Module SMRA Copy F...................... : Ok
Module RDMT Copy 0...................... : Ok
Module RDMT Copy 1...................... : Ok
Module RDMT Copy F...................... : Ok
Module RELI Copy 0...................... : Ok
Module RELI Copy 1...................... : Ok
Module RELI Copy F...................... : Ok
Module PSHT Copy 0...................... : Ok
Module PSHT Copy 1...................... : Error
Module PSHT Copy F...................... : Ok
Module OVR1 Copy 0...................... : Ok
Module OVR1 Copy 1...................... : Ok
Module SPRE Copy 0...................... : Ok
Module SPRE Copy 1...................... : Ok
Module PESD............................. : Ok
Module MFGP............................. : Ok
Module SRST............................. : Ok
Module FLOG............................. : Ok
Module DUMP............................. : Error
Module ##01 Copy 0...................... : Ok
Module ##01 Copy 1...................... : Ok
Module ##01 Copy F...................... : Ok
Module PIDM is not found!
Module not created! PIDM
Test : Reading modules
Reading modules to profile folder (composite)
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\CUSTOM\-UnknownHDD\Data\Modules
Module RSVD............................. : Ok
Module RESF............................. : Ok
Module RAM0............................. : Ok
Module OVR0............................. : Ok
Module RESF(1).......................... : Ok
Module PTCH............................. : Ok
Module CNS1............................. : Ok
Module RWCN............................. : Ok
Module ZONE............................. : Ok
Module PTRT............................. : Ok
Module SRVP............................. : Ok
Module SRVM............................. : Ok
Module CHNL............................. : Ok
Module IDNT............................. : Ok
Module SN00............................. : Ok
Module MISC............................. : Ok
Module ICES............................. : Ok
Module MLBA............................. : Ok
Module QMCN............................. : Ok
Module SMRT............................. : Ok
Module PNID............................. : Ok
Module ABLP............................. : Ok
Module ABLD............................. : Ok
Module SSTL............................. : Ok
Module SERL............................. : Ok
Module SSST............................. : Ok
Module SKPO............................. : Ok
Module DCOT............................. : Ok
Module SRIF............................. : Ok
Module BULK............................. : Ok
Module ALTT............................. : Ok
Module not read (DBGC)
Error : Device error detected (UNC)
Module DBGC............................. : Error
Error : ModStg: composite reading impossible - reading error!
Module OFDT............................. : Ok
Module SMRA............................. : Ok
Module RDMT............................. : Ok
Module RELI............................. : Ok
Module PSHT............................. : Ok
Module OVR1............................. : Ok
Module SPRE............................. : Ok
Error : Module not read (DUMP)
Module ##01............................. : Ok
Modules reading completed
Postby AJ2008 » 11.08.15, 15:06
Sometimes if there is some discrepancy between alternate copies of the same defect list, this can cause symptoms like you suggest. I would try to write p-list form copy 0 to copy 1 and if it writes check if ID is possible now.
