ST500LT012 Showing 0 MB
bikram
Postby bikram » 25.07.15, 14:06
Hi All,
i Have ST3500L012 showing 0 MB
I will try translator recovery after translator recovery without on/off read ID Showing Capacity(capacity not saved when off the hdd) but sector not reading i try the sector reading but showing "UNC error
Same problem ST320LT020 we found most LT hard disk Same problem no scratch in platter we try replace the head also.
Bikram Singh
Thanks & Regard
Bikram Singh
Re: ST500LT012 Showing 0 MB
Postby Amarbir[CDR-Labs] » 31.07.15, 16:56
bikram wrote:Hi All,
Bikram Singh
Hello Bikram ,
Seems To Me You Are From India ,Where Are you From Bai ;-)
Postby AJ2008 » 31.07.15, 17:32
Maybe there are NRG entries that were cleared during translator regen, or some relocation error, surface errors or defective head.
Can you read when using 'read via utility' option?
