WD5000LPVX-75V0TT0 rom/firmware
gabrielknight
Postby gabrielknight » 20.07.15, 12:12
please help me for the following problem.
Head problem drive. All heads crashed. WD5000LPVX-75V0TTO DCM: HHMTJBK PCB:2060-771959-000 revA
Donor drive - WD5000LPVX-75V0TT0 DCM: HBKTJHB pcb: 2060-771959-000
I did the head swap, but the drive working only safe mode.
I can see the serial number and the MB (0)
How can I save the data from the drive? If the donor was not 100% match, could someone send me the right firmware/loader/rom versions?
Thank you!
Techno mode key
Modules directory address............... : 99 443
ROM Modules:
ROM version............................. : 06.1TJ
ROM F/W version......................... : 0006001T
Overlay F/W version..................... : 06.1TJ
Servo F/W version....................... : NE.11
gabrielknight
Re: WD5000LPVX-75V0TT0 rom/firmware
Postby gabrielknight » 20.07.15, 12:13
the donor pc version is Revp2 :(
