how do you get this board into bootcode mode?
I have tried all the short points
made up a few short points of my own
tried board off
tried board on
It always says failed.
whats the trick..
st9500325as - 100535597 board - bootcode
skype: wayne_horner
Alandata Data Recovery
Re: st9500325as - 100535597 board - bootcode
At the dialogue window it shows the boot code pin. You need tweesers to short this pin against one of the screws (for ground). Also, if baud rate is too high then it may fail.
