led 5b 0000
sepid
led 5b 0000
Postby sepid » 30.06.15, 16:33
hi
i ihave a h.d.d 160g 3.5
when power on only bsy !
i doing manual in family
output terminal :
SPW 1.5G LinkOk!5V: 04910
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: FFFF
DAC: 7087
SK C: 0001A30F
ENG>SRV>
SvoTbl Loaded
CL 037D CM 04F1 SL E7EE SM E7AA
BD
FdtTbl Loaded
ofter a min
output terminal :
Sb
WriteSctLog -- buffer not valid
LED 5B 0000
LED 5B 0000
LED 5B 0000
LED 5B 0000
LED 5B 0000
Re: led 5b 0000
Postby AJ2008 » 30.06.15, 16:37
This is some SA error. Does spindle stop after some time? If yes, send some soft reset to it sometimes this will bring it online. You need to find some way to check SA modules, if you cannot get access with drive alone then you will need hotswap donor.
sepid
Re: led 5b 0000
Postby sepid » 01.07.15, 12:45
AJ2008 wrote:This is some SA error. Does spindle stop after some time? If yes, send some soft reset to it sometimes this will bring it online. You need to find some way to check SA modules, if you cannot get access with drive alone then you will need hotswap donor.
hi
no no spindle stop
spin works.
I've done a replacement board
But there is no difference
Garry_TS
Re: led 5b 0000
Postby Garry_TS » 24.11.15, 22:13
Please tell me the model of drive.
In general, you can try to write burn resources (FFlash or HT code) or make a hot swap using a donor with same commutator revision (first two long strings must be same)
Return to “Spin Point”
