mcmt
sepid
mcmt
Postby sepid » 07.06.15, 19:04
hi
i have h.d.d 500 7200.12
f/w: kc45
this is do detect but no id
when run utility start on led ABR
i do test head
- edit id from terminal
- i do short pin
this output terminal :
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
RAW OFF
PASS
MCMTFileHandler: EXCEPTION: Failed MCMT read request
what is MCMT?
plz help me ?
Re: mcmt
Postby AJ2008 » 08.06.15, 10:20
MC = MEdia cache. For this it seems like there is problem with Media Cache and you need to disable it. You can do this with system file '0x93'. After it is cleared try again, but there may be some error with the MC bitmap.
Remove MC options via 0x93 then report here behaviour.
sepid
Re: mcmt
Postby sepid » 09.06.15, 10:39
I've done everything that you've said
but no cheange!!
plz help
sepid
Re: mcmt
Postby sepid » 26.07.15, 17:58
hi
i do disable media cash but no change?
plz help
lcoughey
Re: mcmt
Postby lcoughey » 27.07.15, 21:56
Have you gone back to confirm that your changes to module 93 wrote to the drive?
sepid
Re: mcmt
Postby sepid » 29.07.15, 07:11
hi
i doing ok this h.d.d
no sys file 93
erro in sys file 346
thank you
