WD6400BPVT NEED HELP!!!
minhbdkt
Postby minhbdkt » 06.05.15, 04:39
I Have problem!!
Techno mode key
ROM version............................. : 65.1FE
ROM generation.......................... : 65.1FE
Link table version...................... : 05.0N.
Consolidated ROM version................ : 0065001F
ROM Modules:
ROM Firmware version.................... : 0065001F
Service area:
SA dir reading (ID)..................... : Drive is not ready
SA dir reading (ABA/CHS)................ : Dir reading error ABA 281088 reading error Physical read error C/H/S: -256/1/1 - Device Error Detected: "SERVO ERROR CODE BASE SvirActSync"
thank a lot!!
MINH
Re: WD6400BPVT NEED HELP!!!
Postby AJ2008 » 13.05.15, 11:22
Does it remain powered throughout?
