somebody help.
need pin short for this drive seagate st3250318as with pcb id : 100532367 Rev B
Thanks,
Jinarto
need short pin because busy but can appear F3 T>
Jinarto
Jinarto
Re: need short pin because busy but can appear F3 T>
short pins in the pictures showed with red circles!
http://uppix.com/f-ST10083_1553677f30018c929.jpg
http://uppix.com/f-ST10083_25536784c0018c92b.jpg
Thank u very much rezafarah. i will try.
Jinarto
Jinarto
Hello Rezafarah,
thanks your information about short pin. i have been try but still busy and appear F3 T>
cannot clear smart or clear glist.
Need help
Thanks,
Jinarto
Need help
Thanks,
Jinarto
Jinarto
Jinarto
if F3 T> appear so use this command:
F3 T>/1
F3 1>N1
and this N1 will clear SMART manually.
F3 T>/1
F3 1>N1
rezafarah wrote:if F3 T> appear so use this command:
F3 T>/1
F3 1>N1
This may give you 'INIT SMART FAIL' error on this model.
