DT01ABA300
dataq
DT01ABA300
Postby dataq » 13.04.15, 10:40
Also labelled as HDKPJ08A0A01. Not supported under Toshiba Utility. But if you use the Hitachi-IBM-ARM Utility we found that although the drive would not automatically detect, If you choose either HUASC30ALA6 or HUA7230ALAR, then you can access all areas of the drive including Mods.
rezafarah
Re: DT01ABA300
Postby rezafarah » 14.04.15, 18:39
hi
if this hdd is 3TB i think this model is new and it is not support by UDMA Utility yet.
in Toshiba utility entry try the last option(other Sata).
if you couldn't enter so you should contact ACE technical support.
osity
Re: DT01ABA300
Postby osity » 22.02.16, 22:14
How did you make out with this drive. did you find a utility to work with?
Mine is continuously clicking.....
Filipp_TS
Re: DT01ABA300
Postby Filipp_TS » 29.02.16, 17:19
If drive is continuously clicking it have a hardware issue - problem with the Heads/surface or ROM/whole PCB is not original for this drive.
Return to “Toshiba native”
