where to choose what kind of files to recover?
oldman
Postby oldman » 08.04.15, 21:04
I want to recover *.jpg only,
not *.mpg, *.avi files, how do I choose in DE?
Thanks.
Phil
Spark
Re: where to choose what kind of files to recover?
Postby Spark » 11.04.15, 21:37
To save jpg only (or other kind of files), just, when you're in explorer mode, select ROOT at the top of folder tree, then press right button or if you
prefer ctrl-F, in the search window at the top field type *.jpg , then, when you get results select folder/s file/s you want to save.
Spark
oldman
Postby oldman » 13.04.15, 21:41
Spark,
Thanks for your reply.
seem that it needs that the hard drive is in good condition.
If hard drive is in bad condition, I like to pull out as much as possible, as quick as possible, I hope
[1] DE does not cal the size of folder, some time it is taking long time if drive is bad situation, I prefer to recover files what DE can see and read right way
[2] Somewhere I can choose what kind of files to read, of course, it is the best to ignore these big video *MPG, *.avi files.
Thanks again
Phil
Return to “Data Extractor”
