Hi all,
I have question about original usb drive wd with pcb id : 771801 and donor sata pcb id : 771823
assume original head and rom good. and donor pcb 771823 good.
so rom original + pcb donor install on original drive. what happen ? it direct can get data from this sata drive or need back to original usb drive after repair use sata board ?
Thanks,
Jinarto
PCB id 771801 vs 771823
Jinarto
Jinarto
Re: PCB id 771801 vs 771823
If you have latest dataextractor, you can read data directly with the on the fly decrypt option
