Samsung HN-M500MBB
vaidis1973
Samsung HN-M500MBB
Postby vaidis1973 » 17.03.15, 11:29
What i do bad? I have disk with bad SA, cant read some modules from head 0, etc FIT, Alist. I do do HDD Initialization with had map change in RAM , after i can read sectors. Then i start DE and make build head map and use SA from head 1, but my 0 LBA taken from head 1
thx
Re: Samsung HN-M500MBB
Postby AJ2008 » 26.03.15, 13:08
Sounds like H0 is bad and you will need to replace it (or maybe cleaning may work if head is ok but 'dirty')
vaidis1973
Postby vaidis1973 » 30.03.15, 22:09
Dont have exp. for cleaning head :( I buy donor and try change head.
After head change, same results.
P.S. with new head, can read data, but if encounter bad sector hdd go to knockdown. Need restart with RAM head map change.
datasolution
Postby datasolution » 24.06.15, 22:07
hello Sir,
pls tell us if head is dirty than how and with what we can clean it ? do we have anyting special tool or liquid ?
thanks in advance
