LDR files for "WD3200BEVT-22A23T0" with F/W : 0016000T
betty
Postby betty » 06.01.15, 15:57
Hai all of you,
I need LDR /loader files for "WD3200BEVT-22A23T0" with F/W : 0016000T.I download the files from ACE resources. Model and file is same but the firmware is different. so i can't upload the LDR. I read in our forum, that Mr.AJ2008 wrote that we can change/make/edit the LDR files . How is it possible. also donar is not available. I f any body have these files/any idea please help me
Betty
Crystal
Re: LDR files for "WD3200BEVT-22A23T0" with F/W : 0016000T
Postby AJ2008 » 06.01.15, 16:47
LDR and resource is here (WDC WD3200BEVT-75A23T0 01.01A01):
https://www.dropbox.com/sh/ywsiux9j0yzq ... XpRAa?dl=0
There is '11.rpm' and also entire PCR resource to import (resource is without tracks).
What is the problem with it? Can you access any SA at all?
betty
Postby betty » 07.01.15, 05:21
Hai AJ
thanks a lot.....
I download the ldr from our site exact "WD3200BEVT-22A23T0".01.01...... ". But when i upload it some error message comes on the screen
" OVM ERR NOT COMPAITABLE"
Also the rom version showing " F/W : 0016000T".
IS it the problem with version compaitability or something else ?
And exact problem of HDD is " DRD & DSC is there, But no model,serial,f/w,and 0 mb capacity.
I disabled the head one by one and tried. nothing change.
help me..
Betty
Crystal
Postby AJ2008 » 07.01.15, 10:50
You see DRDY and DSC lights, but is spindle still powered? IF yes then maybe I can help more, but if it is stopped then very likely your issue is mechanical and will need mechanical repairs.
betty
Postby betty » 07.01.15, 11:07
DRD & DSC is there and Spindle is powered and spinning without any noice . at present I copy rom files and service modules ,through the help of another HDD. But by problem is I dont have exact donar. My donar model is: WD3200BEVT-24A23T0 fw:01.01A02.
So let me know, Can hot swap my hdd with this donar.
symptom: no model,serial,f/w,0 mb capacity.
Betty
Crystal
