Hi Guys,
Can You check for Diablo3D firmware from topic. Head map is very important in this case !!! So please check for 5 heads drive firmware with headmap from topic.
4 heads is not correct for my case.
_________________
I need firmware for WD20EZRX-00DC0B0 ver 40050 headmap 01235
Re: I need firmware for WD20EZRX-00DC0B0 ver 40050 headmap 0
Head map ROM module is not dependant on FW version. Simply adjust map in ROM manually to reflect correct head count and map
I know it should not be important, but in this particular case it is, I have conversation and TV support with Maxim and he wrote:
I have tried a lot of things to alive the drive, but all without results. I also had a conversation with WD developers. We have some options for this case.
1. You need to find 02 module from the same FW and same HEAD MAP, and write it to the drive. Maybe the problem is with head map difference.
2. I have found that donor backup contains 431 module while patient backup folder has only 429 modules. You need to find which modules are absent, and write them in patient drive using DIR editor.
There are a lot of free space between 100005 and 200000 ABAs.
3. Smart Hot-Swap. But you still need a suitable donor with the same ROM version and head map.
So if You have such firmware please share. Thx:)
