Using FW copy to access data
odedshankar
Postby odedshankar » 17.11.14, 06:26
Hi Guys,
I have a Seagate ST1000DM003 1CH162-300 FW:CC43.
Drive had beads heads.
I swapped the heads with a good set and drive started and i managed to read ROM and FW.
I started to image the data carefully but the heads dies again and it doesn't get ready now.
is there some way with this family to use the Extracted fw to load into RAM or something similar in order to try and keep imaging?
Nick_TS
Re: Using FW copy to access data
Postby Nick_TS » 18.11.14, 15:50
Hello Oded,
Do you have terminal access?
What is output after /7X
odedshankar
Postby odedshankar » 19.11.14, 05:38
Hi Dima,
I don't have access to the Terminal as heads are dead again.
\What should i expect to see after the \7X command?
