I'm having some cases with 2,5" USB drives, that I can't ID directly thru USB on UDMA.
I get messages that HDD's RAM cannot be read, etc.
Some I can read by terminal.
But now I have a new model (WD5000LMVW-11VEDS6) which PCB (2060-771962) I can't connect by terminal.
Why these messages of HDDS RAM, error, etc? Bad PCB's??
WD USB drives
Re: WD USB drives
Probably it is USB3 drive of FBLITE or ShrekLT etc, some of these models will block vendor commands at SA preventing work with RAM ROM or SA
Re: WD USB drives
Hi AJ
So the only way is to continue to read ROM and write it on donor PCB, right?
