Wd USB 3.0 Detected but shows error code 4f10
Arihant
Postby Arihant » 12.11.14, 07:19
I have one wd10jmvw-11ajgs1 hdd. It is detecting perfectly but does not find Family type in WD usb utility.
I have converted it in sata after that it shows error
"HDD Ram's Reading error - device erro detected " Error code :4f10"
what is mean by Error code 4F10.
How to take SAbackup.
Thanks,
Thanks,
Amit Shah
Arihant Data Recovery, India
Re: Wd USB 3.0 Detected but shows error code 4f10
Postby AJ2008 » 12.11.14, 09:51
It means SA is encrypted and vendor commands are blocked. This is common on new models like Firebird LT.
Arihant
Postby Arihant » 14.11.14, 07:06
Means - Sata conversion will not work for this type of hdd.
The Hdd has one head damage. I would like to disable it in Ram.
What will be solution?
Thanks,
Thanks,
Amit Shah
Postby AJ2008 » 14.11.14, 13:24
It is possible to reach SA and RAM/ROM but I think its not possible to adjust head map in RAM with drive initialise normally. Maybe key is to find some non SA-encrypting model that you can write patient adaptives only to then hotswap, but so far I have not tried this...
Arihant
Postby Arihant » 14.11.14, 16:06
Which family it belogs to. Is any hints to search non encrypted SA hdd for donor.
thanks,
Thanks,
Amit Shah
Postby AJ2008 » 14.11.14, 16:09
Firebird LT I think this model is. Maybe you could HS with firebird (non-LT) which I guess would not have encrypted SA
Arihant
Postby Arihant » 17.11.14, 18:35
Searching the donor hdd
Thanks,
Amit Shah
houman_2h
Postby houman_2h » 18.11.14, 05:59
Start the drive in Kernel mode
Block SA access
Load DIR in RAM
read module by ID
odedshankar
Postby odedshankar » 19.11.14, 10:28
I have got the same issue.
Did you manage to gain access to SA?
How do you block access to SA in kernel mode?
odedshankar
Postby odedshankar » 19.11.14, 10:31
Will hotswap with similar donor will give me access to the SA?
or each drive has a unique key for its SA?
einstein9
Postby einstein9 » 19.11.14, 10:49
Hotswap will NOT work with encrypted SA
tried already long time.
houman_2h
Postby houman_2h » 19.11.14, 22:27
odedshankar wrote:I have got the same issue.
place a paper under the MHA connector
pclab
Postby pclab » 20.11.14, 12:00
Today I got the same error, after a PCB swap...
I'll try your suggestions.
An answer from ACE support would also be great...
Edit: The paper under the MHA didn't solved...
Postby AJ2008 » 20.11.14, 13:57
pclab wrote:Today I got the same error, after a PCB swap...
short read channels
houman_2h
Postby houman_2h » 20.11.14, 21:14
Short E47 PCB to the ground
