ST31000524AS Barracuda 7200.12
SKII
Postby SKII » 12.11.14, 02:43
I have the above harddisk. Firmware : JC45. P/N:9YP154-516.
The PCB is 100574451 Rev A.
The harddisk can be detected by PC3K when powered on. But when I tried to go to Data Extractor, the harddisk becomes BSY.
Do I need to short any points in the PCB?
Thanks.
Goh
Re: ST31000524AS Barracuda 7200.12
Postby AJ2008 » 12.11.14, 09:50
Probably it is SMART error. Can you reach Terminal T> in utility?
VaibhavS
Postby VaibhavS » 09.06.15, 12:02
I have same problem. I cant reach t> terminal. Please give supported firmware files for upgrading.
Postby AJ2008 » 09.06.15, 12:39
Enter utility without power to HDD, open terminal tab, power on, when ready press CTRL+Z for terminal prompt, if not possible then then hold CTRL+Z to reach T> shortly after power on. At terminal, send command to clear SMART.
