Hi there,
After connecting my external WD usb drive it is detected as "WD BAD PCB USB Device"
and no driver is found for "WD Ses USB Device" and the drive is not accessible.
what's wrong with the drive?
Thanks in advance
Re: WD BAD PCB USB Device
Try to get a compatible SATA PCB.
Hello mscerl
Try to solder SATA adapter to USB PCB or use a compatible SATA board.
The list of SATA-USB compatible boards is here:
viewtopic.php?f=35&t=8376
pclab wrote:Try to get a compatible SATA PCB.
Thank you
Maxim wrote:Hello mscerl
Thank you
