ST2000DM001 not ready - shorting points needed
Continuum
Postby Continuum » 21.10.14, 03:54
I have an ST2000DM001 that spins up, no unusual noises, does not become ready.
CTL-Z does not go into terminal
Cannot enter change HDD ID
Terminal output is
Boot 0x40M
Spin Up
TCC-0027[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0027
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0147FB78
[RSRS] 0204
ProcessRWError -Read- at LBA 000000000001A146 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000001A146!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-0027
LED:00000047 FAddr:FFFFFFFE
Which continues and then stops this output. Still no access to terminal
Will shorting points work with this drive?
Here are the image of the board. Can anyone help with shorting points?
I have a board 100664987 REV A
I cannot seem to add attachments as it says "Sorry, the board attachment quota has been reached." no matter how small the image is.
I have uploaded the images to
and
larger images at
http://i.imgur.com/23dqHCP.jpg
and
http://i.imgur.com/apfjxFR.jpg
Maxim_TS
Re: ST2000DM001 not ready - shorting points needed
Postby Maxim_TS » 29.10.14, 16:27
Hello Continuum,
Please see the picture under link. try red pins first, and if they not work, try yellow pair.
http://imgur.com/gksd95B.jpg
Arihant
Postby Arihant » 11.11.14, 06:18
Have you resolved issue with given shorting points?
I have exact same problem. can you have finde the solution?
Roustam says: pin short will not help.
viewtopic.php?f=34&t=7720&p=27179&hilit=100664987&sid=2bd72ff8418f74fc1432c82020c7d389#p26714
Thanks,
Thanks,
Amit Shah
Arihant Data Recovery, India
jinarto
Postby jinarto » 05.04.15, 19:21
Hi all,
if need short pin. how to do shortpin ? i mean only pcb plug to pc-3000 ?
Thanks,
Jinarto
Thanks :D ,
Jinarto
Postby AJ2008 » 07.04.15, 10:00
You need to use tweezers to apply to read channels on PCB during normal drive startup. Short circuit needs to be done at the correct moment to retain access to terminal to allow to make manual repairs with terminal commands which is currently impossible while reaches LED error
