st500dm002 error
cgates
st500dm002 error
Postby cgates » 03.10.14, 10:31
When I connect my st500dm002 to pc3000 express and run the utility, it takes about 5 seconds to be ready and the DRD & DSC light green with a clicking noise..
Inside the utility it show this specification:
Model : ST_M13FQBL
Serial : QNR_BFW
Firmware : 03011630
Capacity : 3.86 GB (8 089 950)
the real specification is:
Model: ST500DM002
P/N: 1BD142-500
FIRMWARE: KC45
Site Code: TK
what is the solution?
Re: st500dm002 error
Postby AJ2008 » 03.10.14, 12:51
The ID displayed is taken from ROM, because SA cannot read. Clicking noise indicates some mechanical failure. If spindle remains on after DRDY then check PCB is native, if after DRDY spindle stops then heads are bad and you would need to check internally before proceeding with any repairs.
