Mariner Family Rom Rebuilding Procedure
mojimorady
Postby mojimorady » 26.06.14, 15:07
Dear Guru
hi
these days I am involved with a WD6400BEVT-75A0RT0 (family:Mariner) which suffers from Rom problem .
the hdd doesn't spin up , after changing the PCB with a same one from same family and writing Rom from same family ,
I am able to read 95% of SA Modules .
I tried to rebuild the ROM and ROM's Modules , but unfortunately i did not succeed .
one of my friends told me that for this family we are not able to do ROM rebuilding .
now how can I recovering the data from this hdd ??
waiting for soonest reply
best regards
Mojtaba Morady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: Mariner Family Rom Rebuilding Procedure
Postby AJ2008 » 26.06.14, 18:23
You can restore ROM from #109 and then write ROM mods from similar donor. Make sure head mapping is the same in resources you write.
mojimorady
Postby mojimorady » 26.06.14, 19:04
dear AJ2008
thank you for your reply
1) I could read the Mod#109 before , now how can I restore ROM using that Module ??
2) I also need Rom Modules resources for this hdd ?
can u help me in both of above things ??
best regards
Mojtaba Morady
Mojtaba Morady
Postby AJ2008 » 27.06.14, 10:27
You need to generate ROM from 109 through utility, then write in kernel mode, after repower write donor ROM modules.
Trying to write complete ROM will likely damage the ROM.
I can help over skype if you have it?
mojimorady
Postby mojimorady » 27.06.14, 13:59
hi AJ2008
I have skype account
My skype ID is : mojimorady
best regards
Mojtaba Morady
Postby AJ2008 » 27.06.14, 17:33
All solved 8)
mojimorady
Postby mojimorady » 28.06.14, 11:25
hi
lots of appreciation to AJ2008
the case was solved
Mojtaba Morady
mojimorady
Postby mojimorady » 28.06.14, 11:26
AJ2008 wrote:All solved 8)
thank u so much !!!!
Mojtaba Morady
