HM500JI stay busy after Hot swapping : No overlay code
hddr49
Postby hddr49 » 19.05.14, 22:02
Hi there,
I have one HM500JI with no terminal output at all.
Let's go for hot swapping...
like another user,
1. Power on donor. Run the utility. Wait until initialization will complete,then put drive to sleep mode. - OK
2. Unscrew the PCB from donor and install it on patient drive.Screw the screws back. And perform recalibration. - OK
3. Wait until the drive will enter ready state, then read the modules from the drive except some "big capacity" log modules. -OK (I read all modules and save)
4. Power off donor PCB and swap it on donor HDA. - OK
5. Write all necessary modules(All of them - family is not in the list) from patient to donor drive .Then switch drive's Power off/on. - stop..
When switch drive's Power off/on then doner HDD is not ready.
It stay busy, and I have terminal output :
Code: Select all
*PA VID=0007 PN=0000 Rev=0004
PSL
U
S_0Shock Sensor Circuit Enabled
SO_1
Init RPM=0
IS=5
CLA #36/74
Handoff RPM=606
SPOK
mS1 00000003
A1O=124 A1G=441
O=511 S=7
SK C:  4558 H:0
Loaded FIT ( 0: 0: 1)
Reso Table Loaded
RRO1X Read OK
No Overlay code
I try to check the modules integrity, but there are 148 of them...
can you help me ?
thanks
Nick_TS
Re: HM500JI stay busy after Hot swapping : No overlay code
Postby Nick_TS » 25.07.14, 15:44
Did you rewrite 73 Overlay?
Postby AJ2008 » 25.07.14, 17:44
And did you write to all available SA copies?
hddr49
Postby hddr49 » 28.07.14, 09:09
thanks for your interest of this case, but case is closed.
I swap with exact donnor (no hot swap, cold swap), and recover all data
thanks again
(other case on WD6400BEVT is harder - make me crazy)
viewtopic.php?f=28&t=8290&p=28844&sid=641cb80a6b556782fe9d73b23678d3b6#p28771
Postby AJ2008 » 28.07.14, 09:49
hddr49 wrote:I swap with exact donnor (no hot swap, cold swap), and recover all data
Overlays from donor must write correctly, then donor ROM gives access.
Great that you got data recovered 8)
