I have a Seagate ST9500325AS spins but not detected under Windows .
PC 3000 gives the message:
HDD family detecting...
Family ID: 3C
Selected family......................... : 3C, Wyatt
Model by ID............................. : ST9500325AS
Loading default settings!
Then press OK!
Tech Key...
Drive not ready
Access violation at address 40004B3C in module 'Vcl50.bpl'. Read of address 53203A18
In the terminal displays:
LED:000000CC FAddr:00259A4D
Help me
thank you
Seagate ST9500325AS not detected under Windows hard drive
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
PC-3000 SSD
PC-3000 Flash
Re: Seagate ST9500325AS not detected under Windows hard driv
Hello Hoang,
Try to isolate spindle motor contact and reach terminal. Then you have to make backup and try to regenerate translator.
Hello Dima
I used Tests -> User commands -> Translator regeneration
Log in:
Executing user command ..................: Translator regeneration
Terminal: reply timeout error
LED: 000000CC FAddr: 0025AF5B
Thank
Log in:
Thank
Dima wrote:Hello Hoang,
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
PC-3000 SSD
PC-3000 Flash
Hoang21 wrote:Hello Dima
Log in:
ThankDima wrote:Hello Hoang,
You cant regen translator while isolated because with PCB detached SA cant read. You need to reach T> after isolated, then send spindown command before reconnecting PCB to HDA. Only then you can reach SA
Thank you IN 2008
I tried to do as you say
In Terminal shows:
F3 T>/
F3 T>m0,6,2,,,,,22
DiagError 00005014
F3 T>
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180
In Log:
Tech Key...
Drive not ready
Executing user command.................. : Translator regeneration
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
DiagError 00005014
F3 T>
I use DE so it displays error message
Thank
Thank you IN 2008
In Terminal shows:
F3 T>/
F3 T>m0,6,2,,,,,22
DiagError 00005014
F3 T>
opts = 00000000
RW Err = 84150180
In Log:
Tech Key...
Drive not ready
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
DiagError 00005014
F3 T>
Thank
PC-3000 Express
PC-3000 SSD
PC-3000 Flash
PC-3000 SSD
PC-3000 Flash
