HD204UI clicks then shuts down
Continuum
Postby Continuum » 21.03.14, 07:07
I have a drive that clicks several times and shuts down.
How do I change the head map in RAM so that I can isolate any bad heads?
Can I use the Rom file from another identical drive to do this?
Re: HD204UI clicks then shuts down
Postby AJ2008 » 28.04.14, 14:51
there is some feature in Samsung utility 'HDD Initialization with head map change in RAM' , try this option
