dd model wd5000AZRX detect and sa modules seems ok but no acces to all lba (it seems next 300,000,000 )
acces to lba with very very low speed in some lbas
and test head is ok
Model : WDC WD5000AZRX-00A8LB0
Firmware : 01.01A01
Capacity : 465.76 GB (976 773 168)
SA SPT.................................. : 1682
ROM version............................. : 65.18J
ROM generation.......................... : 65.19J
Link table version...................... : 38.02.
Consolidated ROM version................ : 00650018
ROM Modules:
Modules directory address............... : 92 115
Heads number in use..................... : 1
Heads map............................... : 1
ROM Firmware version.................... : 00650018
Service area:
Permanent overlay....................... : Loaded
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 1
Head 1.................................. : Ok
with thanks
hamid bidrang
WDC WD5000AZRX-00A8LB0 not access to all lba
