WD5000BPVT-ZEPHYR-55hxzt3
betty
Postby betty » 26.01.14, 08:08
sir,
when i power on the hdd its giving 10 times clicking sound. after that its come on DRD and DSC state. but after the autodetection its showing O CAPACITY. I also try to upload LDR .but after that model : WDCROM MODEL-ZEPHYR_N
Serial number:WDC-ROM SN# XYZ-----
Firmware: 01.01.A01
Capacity: 174.71 GB (366 387 841)
I
But i don't have the exact firmware. I update with something close to match. Please anybody have the exact firmware of the same model please tell me. And tell me what is the problem with my hdd. Is it solve with exact firmware updation?
Betty
Crystal Computers
Re: WD5000BPVT-ZEPHYR-55hxzt3
Postby AJ2008 » 27.01.14, 09:56
If it knocks on powering then it means it cannot read from Servo information. In such case there is some malfunction preventing heads to read, probably heads are bad.
After reach DRDY with 0 capacity, check if spindle is powered or if it stops. I have a feeling it stops and probably you have some mechanical problems internally.
