SEAGATE MOMENTUS 5400.6
compuman
Postby compuman » 17.12.13, 16:41
Hi to all after a long time of absence!
i have a seagate st9250315as which drop down. when initial istall it on pc3000 no id no ready no spin was mark.
After i replace heads with a full compatible donor shows me id its spins and comes ready but with 0 mb in size.
I try hdd lock solution as utility mention
(Tech Key...
WARNING! It`s probably HDD have "HDD Lock (LED: 000000CC)" problem
Try the command: Solution for problem "HDD Lock (LED: 000000CC)"
From menu: Tests -> Solutions
Drive not ready
WARNING! It`s probably HDD have "Translatioin violation (0 GB)" problem
Try the command: Solution for problem "Translation violation (0 GB)"
) but i got this in terminal:
(DiagError 00006008 bly HDD have "HDD Lock (LED: 000000CC)" problem
Spin Errormmand: Solution for problem "HDD Lock (LED: 000000CC)"
Elapsed Time 10.708 secs ions
R/W Status 2 R/W Error 84150180
F3 2> not ready
Test : Solution for problem "HDD Lock (LED: 000000CC)"
Spin Up...
Drive not ready)
What do you think guys ? Thank you in advance
compuman
Re: SEAGATE MOMENTUS 5400.6
Postby compuman » 18.12.13, 15:07
The terminal output when i startup the hdd is
(Rst 0x08M
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180)
