Connecting WD10TMVW through SATA
mscerl
Postby mscerl » 16.12.13, 22:11
How Can I connect the WD10TMVW-11ZSMS1 USB drive to PC-3000 through SATA port?
pcimage
Re: Connecting WD10TMVW through SATA
Postby pcimage » 17.12.13, 08:56
Transfer ROM to a compatible SATA PCB.
rezafarah
Postby rezafarah » 17.12.13, 21:34
what is the compatible sata PCB for this model?!
waleed
Postby waleed » 18.12.13, 17:54
sata 701692
Postby AJ2008 » 19.12.13, 09:55
You need 771692, you can find it on SATA Zephyr, like HXZT series
mscerl
Postby mscerl » 21.12.13, 16:53
is there any way instead of replacing the board?
i've seen someone doing this by soldering special points on the PCB to SATA connector.
it seems that SATA pins are located somewhere on the PCB!
