Sugestion for writing jogs
pclab
Postby pclab » 16.12.13, 10:02
I find the change of microjogs values after a head swap kind of complex to do.
We need to save the 47 module and then write it back.
Why can't you allow to save directly the module? It would be alot easy.
The same with a ROM writing. We need to find it in the database or HDD profile.
What if the ROM file is on a flash drive and we want to get it from there?
Maybe this can be done, but I couldn't find it.
Re: Sugestion for writing jogs
Postby AJ2008 » 16.12.13, 11:10
You need only save donor #47 to make average values and write changes directly to patient #47. Also, when writing from profile you can manually change the path to select alternate location like flash drive.
