Model : ST1500LM003-9YH148
Serial : W110H8GR
Firmware : CC9F
Capacity : 1 397.27 GB (2 930 277 168)
On Power the drive sounds like it comes ready.
Terminal works, can do all the user commands.
But it cant get sector size or read dts or anything else.
on power up terminal says:
Rst 0x10M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
any solution
ST1500LM003-9YH148 SIM Error 1009 RW Error 00000080
skype: wayne_horner
Alandata Data Recovery
Re: ST1500LM003-9YH148 SIM Error 1009 RW Error 00000080
You should repair sys file .
"you should repair sys file"
I have repaired 17a before.
is there any easy way to test the sys files - other than
f3>r17a
f3>r17b
f3>r.......
It doesnt get the dts so there is no sysfile directory that reads automatically when you backup resources.
f3>r17a
f3>r17b
f3>r.......
skype: wayne_horner
Do you write sys17a ?
Tools/utility/view and edit hdd/systemfile
