Seagate ST3500820AS
pclab
Seagate ST3500820AS
Postby pclab » 25.11.13, 13:58
This drive after power, clicks a bit and it goes Ready.
FW: SD-25
I'ts detected right, but with 0 LBA.
When I try to check heads or something in terminal I get the LED error:
LED:000000CC FAddr:0025BF67
or
LED:000000CC FAddr:0028E24B
I have tried the solutions for the LED error, but none have worked.
Can this be really heads?
Re: Seagate ST3500820AS
Postby AJ2008 » 25.11.13, 14:12
Can you reach T> at terminal? Can you check SN displayed with ID is same as what is on label?
pclab
Postby pclab » 25.11.13, 16:01
I can go T.
Serial nº and model it's OK as label.
Postby AJ2008 » 25.11.13, 16:15
And you try to regen translator with no luck? You say it clicks sometime before reaching DRDY, after translator regen what error do you see?
pclab
Postby pclab » 25.11.13, 17:10
I have to try.
I have tried to clear SMART with N1 on terminal, it gives me the same error.
Postby AJ2008 » 26.11.13, 10:29
this is .11 series, there is no NRG list to worry about, and symptoms seem to be common of translator failure, but if it knock heads a little before reaching DRDY it could be some physical problem, this is why I ask you to regen translator, hopefully it will be fine, but if not record here the error you see.
pclab
Postby pclab » 26.11.13, 19:53
AJ2008 wrote:this is .11 series, there is no NRG list to worry about, and symptoms seem to be common of translator failure, but if it knock heads a little before reaching DRDY it could be some physical problem, this is why I ask you to regen translator, hopefully it will be fine, but if not record here the error you see.
After translator regen, the same LED error...
It should be heads...
I have quoted the client already to see if he's willing to continue or not.
Postby AJ2008 » 27.11.13, 12:12
Maybe you can try to adjust head map in ROM. It seems though at least some heads are good, otherwise you would have complete spindle stopped.
Nick_TS
Postby Nick_TS » 29.11.13, 20:15
Since it is an F3 Seagate drive, you should rewrite ROM from patient to donor or resloder the chip onto donor drive PCB.
