I need ROM for Samsung HM100UI/UZ4 P/N: C5072
Best Regards,
Cem Gunal
cemgunal@gmail.com
Re: ROM for Samsung HM100UI/UZ4 P/N: C5072
Damage to ROM on this model is very common. Sometimes matching the date code on the label will get you a donor PCB with compatible ROM version, but for me I prefer to make HotSwap and write both donor overlay modules to patient SA (on all copies) and then you can reach data with donor PCB.
Thank you AJ2008, will try that method. To be exact, which ones are overlay modules?
