Hi there,
while trying to add the defects to the p-list i receive the following error:
"CP Writing error; Device Error Detected 51/19 (AMN;<bit3>;INF"
what's the problem?
Toshiba MK6465GSX CP error
Re: Toshiba MK6465GSX CP error
Hello mscerl,
This is problem of Heads, likely it can't write data.
All defects writing in to modules that placed at platters surface.
Also, AMN-led mean, that head(s) have problem.
Need to check hda inside.
Filipp wrote:Hello mscerl,
Thanks for the reply
Sometime this isnt problem of heads. you should edit plist before add .
