Could anyone provide the loader file for a WD800JD-**TDH** drive please
Kind regards,
Loader file for WD800JD-**TDH** drivre
Re: Loader file for WD800JD-**TDH** drivre
Loader will only work if it corresponds with the ROM version of your disk. what is the ROM version?
Thank you for your reply.
Do you mean FW version? it's: 02.01C03
But when I read ROM, I get:
View ROM information
ROM Data size........................... : 128 Kb
Firmware version........................ : 40.0SM
Heads map............................... : 0,6
ROM Modules
0A : Heads map
0D : Flash configuration
30 : SA Translator
47 : SA Adaptives
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : 6B8/1720
1 : 6 : 64E/1614
ROM Modules
0A : Heads map
30 : SA Translator
47 : SA Adaptives
Micro Jogs
0 : 0 : 6B8/1720
1 : 6 : 64E/1614
