Rom rebuild when module 107 missing ?
entec
Postby entec » 17.09.13, 13:49
How it works exactly when you have regenerated ROM and 107 missing module? thanks
Re: Rom rebuild when module 107 missing ?
Postby AJ2008 » 17.09.13, 14:39
109 is most important module. all others represent ROM modules which can be written from database.
dmarques
Postby dmarques » 18.09.13, 10:56
Have you checked manual to see what's 107 used for?
entec
Postby entec » 06.11.13, 14:56
Yes. Module 107 is (rom modules directory) and is equivalent to the 0B of ROM, but the ROM REBUILD required and the module 107.I'm not clear where to take this module 107 can be made to REBUILD ROM?
In another topic writes that rewrite a ROM database according to "View 90 module information" and then Module 47 recovery from SA and rewrite the ROM and hard disk drive should work. thanks
Postby AJ2008 » 11.11.13, 13:37
AJ2008 wrote:109 is most important module. all others represent ROM modules which can be written from database.
Once written and restored, you can make manual restore of #47 from SA. As long as head map information is same it will be fine.
Other option is to save SA from your drive, write tracks from donor and use donor PCB, then restore native adaptives to SA.
