what is black color for ?
mojimorady
Postby mojimorady » 14.09.13, 13:28
my question is : what are black color sectors ?
I saw in "LEGEND" that they are because of loss of readiness , in "PARAMETERS" i changed "commands to read " , "reading retries" , "jump size" , "direction" etc. to change those black color sectors to green but no success achieved .
any suggestion that tells what are they for and how eliminate them would be vry appreciated
best regards
Mojtaba Morady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
rezafarah
Re: what is black color for ?
Postby rezafarah » 14.09.13, 15:22
hello my friend
as you mentioned,the black sector appears when the sectors is failed to read.in other words when the head could not read the sector properly.
when you try to access data in the DE it is normal that you see some black sectors and that because of HDA damages or SA problems or...
you didn't mention your HDD model,but we can use utility mode in DE,especially for Toshiba and seagate's.in that case we can see that small bad sector areas appears green instead of black.and that not means that black sectors eliminated.that means by using utility mode in DE we can access to data in some sectors that has problem.
Postby AJ2008 » 16.09.13, 10:27
mojimorady wrote:Hello
This would help in case of sectors showing red or yellow, for sectors showing black there is some hardware error in reading that specific position. If all sectors read black It could reflect damage to zone table or translator not loaded or even some physical issue.
mojimorady
Postby mojimorady » 16.09.13, 16:07
hellOOO
Dear Rezafarah
tnx for your reply
this h.d.d is seagate 500GB 2.5"
when i connect it to pc3000 , in DE i can see its 4 partitions , but not the ROOT . so i should run Search NTFS Structure
but after reading about 7000 LBAs they become black
-- any orher things should I mention to them ?
-- what should I do to recover the Data ?
Dear AJ2008
Also tnx for your reply
how can I understand the what the problem is ?
and guide me to recover the data please ?
best regards
mojatab Morady
Mojtaba Morady
Postby AJ2008 » 16.09.13, 16:09
mojimorady wrote:this h.d.d is seagate 500GB 2.5"
So you can read only part of the disk? Did you make translator regeneration on this model? Or clear defect lists?
mojimorady
Postby mojimorady » 16.09.13, 18:05
Dear Friend
i did nothing on it , i just did what i told before .
now what is the first step ?
regards
Mojtaba Morady
rezafarah
Postby rezafarah » 16.09.13, 22:42
mojtaba jan!
if you want you can call me, I'm from Shiraz.
if you will,tell me to give you my number.
mojimorady
Postby mojimorady » 17.09.13, 08:40
hello
it is my pleasure to have your number
mojimorady@msn.com
mojimorady@ymail.com
best regards
Mojtaba Morady
Return to “Data Extractor”
