Dear Support,
Its been really really a long time since the last udma Update
we have some issues here with those new families which are not supported yet
WD 2.5
Shrek : Not Supported yet
ShrekLT : Not Supported yet
WD 3.5
Tressels : Not Showing the HM in ROM - All Blanks
Trails : Not Showing the HM in ROM - All Blanks
In Addition to some other Models which i cannot remember now, Still there are issues on working with them
Something else About Toshiba Drives as well
-- some families when you try to Set Max and use lower value, you cannot set it back again to original Size
once you power off/on again it comes back to the lower value but still can work with it in DE
When can we expect the next update on the English ver. of UDMA?
I know for sure the Russian ver. of UDMA has those updates even months before the English release.
thank you
waiting for your comments here
Updates for those Acelab Support
Re: Updates for those Acelab Support
By the way
The Chinese DFL tool for WD can read/backup FW from USB 3.0 with DIRECT USB CONNECT - if the drive is healty
udma up till now we are accessing via Terminal ONLY
is there any updates about this issue as well,
thank you again
thank you again
Thanks einstein9 to open this topic here,,
as you mentioned about Wd . there is some i can add here about other kinds
Hitachi the new drivers especially 3.5 passwords is not working and needs to update
Toshiba we need new powerful commands like stop head and format with p-list ...etc
Fujitsu there is alooooot of unsupported models and families
seagate the new Samsung seagate need some updates
Well Based on my Log here
Updates in 2012: 3 Updates been Added
1- Begin Jan 2012
2- Middle April 2012
3- End of June 2012
you may see their website for the correct update release
but this year 2013 seems NOTHING SO FAR, which is really Upsetting me here
we get daily new drives and nothing much can be done here
1- Begin Jan 2012
3- End of June 2012
- digitalsupport
- User
Looks like a new version is just around the corner, the russian version was updated 30-7-2013 according to the russian Acelab site.
Digitalsupport
Digitalsupport
Am wondering WHY ACELAB SUPPORT are not saying anything here??
The new version of PC-3000 Ver. 5.5 and Data Extractor Ver. 5.0 software is available.
http://www.acelab.eu.com/pc3000.ver5.5.php
but unfortunately with no Fujitsu or Hitachi updates!
Dear Acelab Support n Developers
Is there any plans for Toshiba feature which is working with Head Map in RAM or ROM?
or because of some other issues about it?
thank you
and btw, thank you for the new 5.5 update, a very good options been added and the UI for WD looks better now
thank you
iIs there any support model for Hitachi CinemaStar drive which is C5K500 family.
Drive mostly use @ DVR recorder or Set Top Box. We failed to reuse the drive, failed to read/write into sector. Failed to do low level format.
We have PC3K but not supported family, we want to work @ SA area to change the firmware.
Any solution would be appreciate.
Dear Support,
we still waiting for those new families of WD as i mentioned before
and still getting new
2.5 WD:
Shrek
Shrek LT
FBLite
3.5 WD:
Trail XLS
Diablo3S
for me here dealing with 2.5 my passport drives is on daily bases (3-5) daily
thank you
2.5 WD:
Shrek
Shrek LT
FBLite
3.5 WD:
Trail XLS
Diablo3S
thank you
