unreadable sectors on seagate st2000dl001
farjad
Postby farjad » 05.08.13, 12:00
I have a seagate st2000dl001 , and Firmware CC98, When i view sectors after 2000000 i got the unreadable sectors,
Anyone can help in this,
best reg.
gh. farjad
Re: unreadable sectors on seagate st2000dl001
Postby AJ2008 » 05.08.13, 13:05
Did you rebuild translator before trying to get access?
farjad
Postby farjad » 05.08.13, 13:52
no i dont rebuild translator
Postby AJ2008 » 05.08.13, 13:54
Probably someone has rebuilt translator and NRG is not right, or it has some level of pending bug. Do you see any information in Terminal field?
farjad
Postby farjad » 06.08.13, 11:11
No, it`s empty
Postby AJ2008 » 06.08.13, 11:41
You are sure there is no terminal output at all? :?:
farjad
Postby farjad » 06.08.13, 11:49
Yes of course.
Postby AJ2008 » 06.08.13, 12:03
But you get "T>" after pressing CTRL+Z?
farjad
Postby farjad » 06.08.13, 12:18
thanks, that`s write
the massege is
ASCII Diag mode
F3 T>
Spinning Down
Spin Down Complete
Elapsed Time 14.516 secs
Delaying 5000 msec
Jumping to Power On Resetÿ
Rst 0x20M
(P) SATA Reset
RAW OFF
PASS
Postby AJ2008 » 06.08.13, 12:45
With terminal connected, at your task in DE select 'Work with active utility' then select 'No' at the next prompt. Now try to read sectors .
farjad
Postby farjad » 06.08.13, 13:23
Please Tell us more about it ( at your task in DE select 'Work with active utility' ) or how do it?
Postby AJ2008 » 06.08.13, 14:04
Select 'Task Parameters' -> 'Command to Read' -> 'Read from Active PC3000 utiltiy'.
Nick_TS
Postby Nick_TS » 23.08.13, 16:58
Try to increase Terminal timeout.
