WD 2.5 Scorpio Blue (WD5000BEVT-00A0RT0)
sosrecup
Postby sosrecup » 24.07.13, 16:34
I have a WD 2.5" Scorpio Blue (Model WD5000BEVT-00A0RT0).
When I connect it to PC3000, it is recognized and it reaches readiness. When the drive spin, I can hear a strange sound.
When I run the utility, the model in not recognized and when I choose the model Scoprio, I get the logs bellow:
ROM version............................. : 16.0SW
ROM generation.......................... : 16.0SW
Link table version...................... : 07.17.
Consolidated ROM version................ : 0016000S
ROM Modules:
Head Map Reading Error.................. : Head map check sum error
ROM Firmware version.................... :
Service area:
SA dir reading (ID)..................... : DISK SERVO SPINDLE SPINUP ERROR
When I access the Kernel mode, I can read ROM but not SA. when I try to rearch SA by region, I get error and it recommaend to use an LDR file.
Any procedure or solution to resolve the problem please?
Kind regards,
Re: WD 2.5 Scorpio Blue (WD5000BEVT-00A0RT0)
Postby AJ2008 » 24.07.13, 17:04
does it remain powered constantly? Do you have a LDR you an use?
If you have good donor you can try several things:
Put donor (non-native) PCB on, see if it still makes the same "strange sound"
With non-native PCB on, load LDR saved from your donor (this will match ROM version)
Try HotSwap
To help remotely is difficult, but assuming your media remains powered a hot-swap should give some level of access, even if just SA access to begin with
sosrecup
Postby sosrecup » 25.07.13, 11:08
Many thanks for you answer.
Unfortunately I don't have a donor drive.
I hear 5 times a quit sound then it stops.
I'm searching for an LDR file and I'm trying to use another headmap
Kind regards,
Postby AJ2008 » 25.07.13, 11:24
Seems like head failure. Also, this is mariner not scorpio so maybe your utility doesnt have correct support for it? What utility version are you using?
sosrecup
Postby sosrecup » 25.07.13, 16:22
The drive stop spinning after I hear 5 times a quit sound. It should be a bad heads.
I have the last version 5.2.4. The drive is recognized with Marnier but on the top of the HDD, its written Scoprio Blue (see photo)
cuumaytinh
Postby cuumaytinh » 04.09.13, 12:13
I think . IS bad head .
