Toshiba 3.5" MK1002tskb Firmware problem.
Arihant
Postby Arihant » 20.06.13, 12:46
Toshiba MK1002tskb, 3.5", 1 TB, Part No. HDD3b04czk51, FW Mt4A, REV No. A3, HDD is detecting slowly. No Clicking Noise.
Utility does not has option for the Toshiba 3.5" HDD.
Can't Access the any Sector. Sector edit gives read on every sector.
I can access the terminal prompt >. I Don't know the Terminal command for Clear G-list or Lba to chs conversion.
How to create custom type in toshiba for 3.5"
Thanks,
Amit shah
Thanks,
Amit Shah
Arihant Data Recovery, India
Maxim_TS
Re: Toshiba 3.5" MK1002tskb Firmware problem.
Postby Maxim_TS » 21.06.13, 09:24
Hello Arihant,
There is no universal solution, but you can try next:
- power off;
- isolate spindle contacts, power on, must be BUSY, it dissapeared within some time, LEDs are off;
- softreset (or hard reset), must be ready in few minutes;
- (optionally) read ID, very slowly ID reads;
- Tools->HDD->standby
- remove isolation, screw the PCB to HDA;
- Tools->HDD->Recalibration
- read ID again, try to read the data
Arihant
Postby Arihant » 22.06.13, 07:51
The HDD PCB's one screw is not opening. Trying to opening pcb with other tools and let you know soon.
Thanks,
Thanks,
Amit Shah
Return to “Toshiba native”
