Hello.-
I tried to rebuild ROM in this laptop drive, but an error appears at the end of the process. I dont know if I am missing something.
The drive is completely dead because PCB damage.
1. I connected donor PCB in patiente drive, starts okey and I can read modules.
2. I remove the PCB from HDA and connect to PC3K, alone, then power on and run the utility, select Marvell familiy correctly in Kernel mode.
3. Then I starts ROM build from SA data, select profile folder and write modules
4. At the end an error appears as you see in the attached file, why is that, what I am missing?
The ROM build process is made with PCB connected alone without HDA, is that correct?
Thanks in advance.
Cyl Count............................... : 128
ROM version............................. : 06.1AC
ROM generation.......................... : 06.1AC
Link table version...................... : 01.2E.
Consolidated ROM version................ : 0006001A
ROM Modules:
SA defects assigned..................... : 1
ROM Firmware version.................... : 0006001A
From folder............................. : <HDD Profile>\Data\Modules\
Save results into....................... : <HDD Profile>\Data\ROM\Build
ROM writing............................. : Ok
ROM module 0A writing error Data request error - Drive is not ready
DRC
WD McKinley 2.5 ROM build from SA data ERROR
