I have following HDD.
Model : ST9500325AS
Serial : 5VEFCCXR
Firmware : 0002BSM1
Capacity : 465.76 GB (976 773 168)
if i starts to make image of this hdd,i starts copying but after some time its stops reading LBA(Yellow),then i if repowered 2-3 times copies some time again.
WY05D7.BSM1.DA99LL.0002BSM1
Requesting FW Pkg ver ........
ID Len
0 2 Reserved Defect Table (SA defect table)
3 1870 Primary Defect File (P-List))
4 9 Servo Adaptive Parameter File (SAP)
6 85 Read Adaptive Parameters File (RAP)
8 2400
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
26 80 Drive Self Test (DST), Head 4
27 80 Drive Self Test (DST), Head 5
28 80 Drive Self Test (DST), Head 6
29 80 Drive Self Test (DST), Head 7
2B 535 R/W Operating Parameters (translator, etc)
2F 432 Data Integrity Check (DIC), HEAD 4
30 432 Data Integrity Check (DIC), HEAD 5
31 432 Data Integrity Check (DIC), HEAD 6
32 432 Data Integrity Check (DIC), HEAD 7
33 4576
35 26 SMART Data
Collecting DT Infos...
ID MemOffs Len
0 6020100 43520 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4000000 4096 Servo Adaptive Parameter File (SAP)
8 10070000 948
A 60A1970 1024 Seek Profile
12 100D4000 104
13 60AC9F0 768 Dependent Zone Table for User Area
14 60ACCF0 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60AB7D8 4632 Dependent Zone Group Tables for User Area
1C 60AB698 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020380 3216 Zone Format Parameters File
ID MemOffs Len
2 60201F0 400 Zone Table
6 227840 40996 Servo Flaw Table
8 10070000 948
12 100D4000 104
16 6020100 32 Drive Configuration Table
17 6022A60 1616 Temperature Control Configuration
1F 6144678 1728 RW working user preamp table
20 6144D38 72 RW working system preamp table
Collecting DT Infos completed
Detecting Phys Sct Size...
If i starts its copying all,after certain time by 4-5 mins ,after that ready states goes to continuous blinking DWF ERR.then unable to read .at this state if i turn off/n ON(F12)
starts copying(Like Loop)
Any suggetions
ST9500325AS
Re: ST9500325AS
uncheck all options under 'HDD ID EDIT' and try again.
Re: ST9500325AS
Thanks AJ2008 for reply
Just tried now seems working.
i strated copy data to image file but its very slow.
Thanks alot again
Thanks alot again
Re: ST9500325AS
Thanks AJ2008 worked but now
while imaging speed is very slow.So i build head map and observed that if disable Head 02 copying fast.
But if i read by Head 02 it reads data intermittently,some time read sometimes not.But if i read LBA manually it reads.
Head Check & Copying Log
Head 00 Resistance 0138
Head 01 Resistance 00EB
Head 02 Resistance 01DB
Head 03 Resistance 010C
->LBA = 180,040,892, Step = 256 [Drive is not ready!!!]
Software reset... Ok
->LBA = 180,041,892, Jump = 1,000
<-LBA = [180,040,892..180,041,892], Step = 1
->LBA = [180,041,892.. ], Step = 256
->LBA= [180,041,892.. Skip Sectors
->LBA = 180,042,893, Jump = 1,000
<-LBA = [180,041,893..180,042,893], Step = 1
->LBA = [180,042,893.. ], Step = 256
->LBA= [180,042,893.. Skip Sectors
->LBA = [180,042,895.. ], Step = 256
->LBA = 180,042,895, Step = 256 [Drive is not ready!!!]
->LBA = 180,044,088, Jump = 1,000
<-LBA = [180,042,895..180,044,088], Step = 1
->LBA = [180,044,088.. ], Step = 256
->LBA= [180,044,088.. Skip Sectors
->LBA = [180,044,090.. ], Step = 256
->LBA = 180,044,090, Step = 256 [Drive is not ready!!!]
->LBA = 180,045,093, Jump = 1,000
Re: ST9500325AS
Thanks Alot AJ2008 case resolved DR Done
Thanks again for your suggestion which worked.
