ST3000DM001 BSY DSC DRD and motor stops cannot terminal in
The drive does not let you terminal in or control z, is there points on the pcb where you can short the pcb and get the terminal working?
Re: ST3000DM001 BSY DSC DRD and motor stops cannot terminal
Please provide the board picture into the forum.
Usually, reading channel lines are shorted across with element. So you can check my picture and find it by yourself.
Check my example picture and see for the same lines on your pcb.
Black circle show the element that shorts two lines.
The pic for this pcb is attached... 100664987 rev A. The one posted is not the one for this drive..
Try this points
