Re: Model : ST31500341AS
alphapune
Postby alphapune » 06.01.13, 07:33
i have following hdd
Serial : 9VS372TK
Firmware : CC1H
Capacity : 1 397.27 GB (2 930 277 168)
It was in busy state.
i tried busy state solution and it resolved
but if i tried partition analysis ,showing data green Z icon (pic attached)
this hdd is attached as secondary (as i discussed with customer he said no encryption,no raid,no hdd password)
So please guide.
Postby ACE_Admin » 06.01.13, 09:30
z - stays for zipped. Windows zip files on its own, when its option is set.
When file system has no serious problems, it is possible to save those files. Have you tried that?
If that will fail, you can try to mount the file system after partition analysis to your current OS and see what will happen.
alphapune
Postby alphapune » 06.01.13, 09:49
Thanks Alot
but can you give some detailed procedure
if yes it will great help
alphapune
Postby alphapune » 06.01.13, 16:06
problem resolved thanks
Return to “Data Extractor”
